Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Zanussi ZDV12002FA Dishwasher Not Heating
- This topic has 24 replies, 4 voices, and was last updated 7 years, 4 months ago by
purplemonkeydishwasher.
December 1, 2018 at 8:38 pm #459268
Moderatorwater flow problems, lack of water and heater is on for some reason, lime scale build up or because it wants to
you have to understand all these heaters have safety fuses so in thee vent of the heater coming on with little or no water then the fuses blow to prevent fire
December 4, 2018 at 4:05 am #459269Jous
ParticipantHi,
Have same problem with overfilling. The cycle stars and finishs with the overfilling via two little black hoses that activates the antiflow system. Read about your replacement of presure sensor. Have information about this? How to check it or knowing that is the problem?December 4, 2018 at 9:29 am #459270electrofix
ModeratorJous wrote:Hi,
Have same problem with overfilling. The cycle stars and finishs with the overfilling via two little black hoses that activates the antiflow system. Read about your replacement of presure sensor. Have information about this? How to check it or knowing that is the problem?some of these units have pressure sensor modifications
will need model and PNC number to check if yours is coveredit was done to stop the pressure sensor blocking up and giving false readings
December 4, 2018 at 11:38 am #459271Jous
ParticipantHI,
Zanussi model ZDV12002FA, PNC 91107900201
December 4, 2018 at 1:42 pm #459272electrofix
Moderatorhere is before and after pics
if your sump is like left one it needs modding ( take basket and filter out to lookDave
December 4, 2018 at 4:38 pm #459273Jous
ParticipantOk, is the one on the left. Any information of how to dismount it and how to checking if It is working
Thanks a lot!December 4, 2018 at 9:36 pm #459274electrofix
Moderatorin that case order the kit and fit it. if it does not cause problems now it will in the future
there is a small hole where the water pressure activates the switch and it clogs up causing problems. the switch clips on to the sump the other side of that hole
December 6, 2018 at 11:30 am #459275Jous
ParticipantOk. I clean this pressure sensor and know dishwasher finish cycle. I’ ll monitor for some cycles. One I can see any problem I’ ll go for the new kit. Thanks for the help. I apreciatte
November 2, 2025 at 12:45 pm #459276Hunuser100
ParticipantSziasztok! Új vagyok a fórumon így elnézést ha valamit nem tudok. Ugyanilyen készüléken ugyanez a hibajelenség van miszerint nem melegíti a vizet fel. Kicseréltem a fűtő egységet, de kimérve a leírtak alapján az előző is jó volt mert 25 ohm értéke volt. Megmértem a hőmérséklet szenzort ami 20 fokon kb 3,8k ohm volt. Hajszárítóval próbálva szépen csökken melegre aztán visszaáll. Ezen felül hogy tudom kizárni a hibákat és megtalálni a hibás alkatrészt? Köszönöm a segítséget.
Hello! I’m new to the forum so sorry if I don’t know anything. I have the same problem on the same device, that it doesn’t heat the water. I replaced the heating unit, but based on the measurements, the previous one was also good because it had a value of 25 ohms. I measured the temperature sensor, which was about 3.8k ohms at 20 degrees. When I tried it with a hair dryer, it drops nicely to warm and then returns. In addition, how can I rule out errors and find the faulty component? Thank you for your help.
November 2, 2025 at 1:25 pm #459277electrofix
Moderatorif its exactly the same unit there is a tacho coil on the back of the motor that goes open circuit. if this goes it wont heat
zanussi dont supply the part but the beko coil fits ok
