Re: Zanussi ZEBF249W icing up
Don,t know this model off top of my head but what i do know is if it has a mechanical timer as you describe, what “stops the heater when it gets to a certain temp” there is a defrost thermostat in line with heater that will only allow the heater to come on when the evaporator is frosted (during the defrost mode timed by the timer) if during this time the temp gets to a certain level before the end of the defrost cycle the stat will cut out the heater.From what you describe replacing the timer should solve the problem
Subs
