i have the above freezer and the fridge keeps warming up.
upon investigation the evaporator in the freezer is completly frozen.
when i defrost it all is well for a week or so then the same happens again.
i have done a bit of research and the common problem would seem to be the auto defrost system and a problem with the heater or the timer
problem is i have tested the heater and it works ok (applied ac and tested continuity) both with and without the overheat protectors in line and it heats up ok.
there does not seem to be a seperate timer as i think it is controlled by the main pc board.
any suggestions as im running out of ideas. and dont like the idea of changing the pc board at £100 in case is something else.
Mark
