Zanussi ZI921/8 FFA. Prod No. 925771721
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZI921/8 FFA. Prod No. 925771721
  • #79143
    Alanj
    Hi Guys, customer called to say this built in F/F , freezer working ok, but fridge not cooling. Anyone know likely cause on this model?
    Alan
    #408135
    Criscold
    Re: Zanussi ZI921/8 FFA. Prod No. 925771721
    Do you know if the unit is running continuously ?
    #408136
    Alanj
    Not sure. Will find out.
    #408137
    Alanj
    Customer says appliance is working normally just fridge not cooling.
    Alan
    #408138
    Alanj
    UPDATE! Must have planted a seed of doubt in customers head. Now thinks appliance is running constantly. Fridge compartment at around 10 degrees C.
    Alan
    #408139
    Criscold
    The freezer on this is frost free but the fridge is not, If the unit is running and only getting down to 10 deg I would think that they have a system fault on this one.
    Let me know if you req the manual on this
    Colin
    #408140
    Alanj
    How does the fridge regulate if it’s not frost free? There is no separate control for the fridge.
    Alan
    #408141
    Criscold
    Unlike the NO FROST refrigerators, in the PARTIAL NO FROST type the cooler and freezer compartments are separated physically.
    The battery evaporator cools only the freezer compartment, while the tube evaporator cools only the cooler compartment.
    The cold produced by the battery evaporator in the freezer compartment, is distributed by the fan placed behind the screen
    A temperature sensor is mounted in the fridge section and controlled by the circuit board
    #408142
    Alanj
    Thanks Colin.
