Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zanussi ZJ1217
- This topic has 11 replies, 4 voices, and was last updated 18 years, 3 months ago by
timdowning.
December 17, 2007 at 4:48 pm #33069
timdowning
ParticipantAdvice required please.
Zanussi is a make i don’t normally repair. I don’t have the TDS disc.
Reported fault is the lights are on, door clicks, but nothing else.
Thanks.
December 17, 2007 at 4:54 pm #237309Martin
ParticipantRe: Zanussi ZJ1217
timdowning wrote:Reported fault is the lights are on, door clicks, but nothing else.
It’s the same as all the other Zanussi’s Tim with an EMW2000 board in it. Just suss out those error codes etc etc and away you go! 😉
Oh! Do get a TDS disk by the way….priceless info for bugger all money! 😀
December 17, 2007 at 4:59 pm #237310timdowning
thought that might be the case.
As i am going tomorrow and have no TDS disc can you tell me how to access the error codes and what the error codes are?
Thanks.
December 17, 2007 at 5:00 pm #237311senseib
This type of fault can often be attributed to a loose edge connector on the pcb at the front of the machine – disconnect it squeeze connections together and reconnect, might be all that’s needed 😉
Good luck! could be Xmas come early 😀
Brian.
December 17, 2007 at 8:08 pm #237312Martin
timdowning wrote:As i am going tomorrow and have no TDS disc can you tell me how to access the error codes and what the error codes are?
Have you ever looked in the sticky in this forum “Known Error Codes?” 😉
December 17, 2007 at 8:30 pm #237313timdowning
Yes thanks.
The only Zanussi codes I can find relate to the “EWM1000” pcb.
Are these codes and test procedure the same for the
EMW2000
PCB?
December 17, 2007 at 8:38 pm #237314Martin
Yes, they are very similar 🙂
Don’t forget to add a TDS to your list for Santa! 😉
December 17, 2007 at 8:52 pm #237315timdowning
Great. Finally feel like I’ve got somewhere. 😀
Thanks Martin for your ‘maze’ like guidance. 😉
Thanks Brian for your suggestion about the edge connector. Lets hope its just that. Nothing like being prepared though.
Cheers.
December 18, 2007 at 5:18 pm #237316timdowning
Right here we go……….
when you turn the selector the leds light as they should.
when you press start the door clonks three times. then the second and eigth light flash. (leds 2 and 8). Now if i have worked this out correctly this is error 41 door problem?
I have tried to put it into diagnostics mode by doing the start and one option button pressed while turning selector once clockwise. I cannot get it to go into diagnostics.
Do you think this is just a door interlock problem or board fault.
I have checked all wiring and insulation tested the machine, all ok.
Thanks.
December 18, 2007 at 7:12 pm #237317Martin
timdowning wrote:Do you think this is just a door interlock problem or board fault..
OK, error E40 or E41 does relate to it being a faulty Interlock, so first option would be to replace it. Also it is worth noting that the m/c tries to access the programme within a time-scale of just 15 seconds….after that it displays an error code whenever possible? 15 seconds may well be the time period you observe for the Interlock to click just 3 times?
The other likelyhood is that the Interlock itself has blown the triac on the main board and only trying a new Interlock will help solve that possibility? The conclusion therefore being both Interlock and PCB required! 😯
HTH? 😉
December 18, 2007 at 7:29 pm #237318timdowning
Yes it does help.
Thankyou Martin.
December 20, 2007 at 11:39 pm #237319whiskeyjack6058
Went to an aeg machine, which was just dead. Main controll PCB (ewm2000) stunk of burnt electronic components. Changed it along with the interlock and customer is happy. Its just a bit spooky having to play around with modules when we dont really understand them. I hate this job, but I love it really. Bit like my wife..
