Zanussi ZJ1217 91451010802 Fault Codes
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZJ1217 91451010802 Fault Codes
  • #67003
    Bernie
    Does anyone know how to read the 8 flashing LED’s on this machine and convert them into a fault code please?
    I have the fault code list.
    Thanks in Anticipation
    Bernie
    #365962
    Re: Zanussi ZJ1217 91451010802 Fault Codes
    Bernie wrote:8 flashing LED’s
    EIGHT flashing LED’s????
    The display panel should show an E?? code if an error is detected by the electronics. But what is the problem with the machine anyway?
    #365963
    Bernie
    The problem was LED 2 & 8 flashing E41 door lock, which I changed and machine ok now. Found this on UKWhitegoods.
    I just wanted to know how to read the eight vertical LED.
    I did look on Distriparts DVD could not find anything.
    Thanks for the reply Martin
    #365964
    Bernie wrote:I did look on Distriparts DVD could not find anything.
    Oh it’s there on the DVD for sure. Fire up that model no and PNC again then look at ‘Service Manual (4th one down) Document no: 599352684
    HTH? 😀
    #365965
    Bernie
    Thanks Martin
