Zanussi ZJD-12191 Cycle won’t start
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi ZJD-12191 Cycle won’t start
  • #55813
    pinkgiraffe
    My built in machine allows me to select a cycle and appears to start with a draining sound but then the indicator that shows you where you are up to in the cycle moves to the end symbol, the time remaining goes to zero and the door unlocks. There is no error code and I have checked all the pipes and filter.
    Any help would be much appreciated.
    #325229
    Re: Zanussi ZJD-12191 Cycle won’t start
    Usually some sort of corruption issue caused by earth leaks on the motor or heaters. You need a Meggar or insulation tester to solve this one.
    Power off if you’re going in yourself.
