Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zanussi ZJD1219
- This topic has 8 replies, 4 voices, and was last updated 16 years, 7 months ago by
Toni.
August 15, 2009 at 11:40 am #47814
Toni
ParticipantHi
I have just fitted a wash pump to this model
Now when you select any programe on this it just goes to 3 mins on drain then switches off (after draining )
Can it be that its stuck on fault mode?
can it be reset ?
Chers toniAugust 15, 2009 at 7:40 pm #294667electrofix
ModeratorRe: Zanussi ZJD1219
there are three of these machines need prod number to find which 1
are you getting a fault code coming up ?as a long shot i assume the progammer knob is working and you are not selecting the same programme every time
regards
August 16, 2009 at 5:28 pm #294668Toni
ParticipantRe: Zanussi ZJD1219
Hi Dave
The programe knob seems to be ok.
I turned it to 0 (Off) waited for it to cancel, then put it on any programe, it shows the time remaining (eg 2.30hrs) starts to pump then the display goes to 3 mins, pump & drum turns then swithes off at end :rolls:
reprograme it on any programe & it does exactly the sameThe PNC is 914601904/02
any help on this would be really good.
The original fault was the wash pump had completely burnt out (All melted)
ToniAugust 16, 2009 at 5:59 pm #294669iadom
Oh dear, usually takes out the main PCB when this happens. 😥
Damage is normally obvious.
August 16, 2009 at 6:03 pm #294670Toni
I have checked the PCB and can find no obvious damage 🙁
August 16, 2009 at 6:29 pm #294671iadom
Can you run it through diagnostic mode?
Sent you some stuff, hope its not a built in one. 🙂
Its quite a big file, hope you have a BB connection. 😀
August 17, 2009 at 7:53 am #294672Toni
That brilliant
Thanks BanksieToni
August 18, 2009 at 7:17 am #294673Toni
Unfortunatley the manual doesn’t give me any fault codes or how to reset machine (Very much appreciated anyway) 🙁
If anyone has any info on this I would be really gratefull, otherwise I think he will just scrap itToni
August 18, 2009 at 8:00 am #294674Martin
The board will only reset if it isn’t itself at fault. I’m pretty sure you’ll find that the drain pump triac has blown. Take a close look on the track side of board and triac marked Q2 on the board adjacent pump connector block.
