Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › ZANUSSI ZJD1219 DRAIN PROBLEMS
- This topic has 6 replies, 3 voices, and was last updated 14 years, 9 months ago by
expertcat.
June 30, 2011 at 1:31 pm #63682
expertcat
ParticipantBeen out to this devil of a machine.
Original call Totally dead.Fit new module still dead fit the front pcb now starting to get life in this thing.
Program it up tests out with no hick ups.
Get a call back to it showing fault code water valve faulty.
Replace valve though gottya…
Only to wrong
Offers no fault code but when in dryer mode no drain pump action.
drum turns water is injected dryer heaters operate fan blows but the drum starts to slowly fill with water no drain pump operation.
So clothes go in the machine wash and spin and when drying gets completly soaking wet.
Checked condenser and its clear of fluff (like new).
Have I missed something or is it a poss faulty module???
Any help mucn appreciated.
June 30, 2011 at 4:32 pm #354531BobHope
ParticipantRe: ZANUSSI ZJD1219 DRAIN PROBLEMS
have you checked the dryer heaters with a insulation tester as these give strange symptoms just as you decribed.
Bob.
June 30, 2011 at 11:46 pm #354532leavemetogetonwithit
What caused the original board to die?
Mike.July 1, 2011 at 5:00 am #354533expertcat
I was told it was for a start intermitant dying. Machine would just go dead. When I went there it started display all came on then it went dead. Changed main pcb still dead. Changed front pcb and light came on. Changed module back dead again. Refitted new module working. So had both pcbs fitted. Then he complained fault code would come up which was the cold water valve on drying cycle. Indeed valve was brown instead of White replaced that. But now the clothes get soaking wet instead of drying the clothes. Sat there and watched within 10 mins of drying operating water appears in bottom of inner drum and no drain pump running.
It’s one of those possessed machines
July 1, 2011 at 9:01 am #354534leavemetogetonwithit
Presuming you’re getting E10. Advanced search for “E10” in TT Enqs brings up these 126 results,
most of which look approximately relevant.
Think a trawl through them might help. My gut feeling is there’s something not quite right about that valve coil. You said the old one was brown. All the ones I’ve seen have been green.
And another area to look at would be pressure switches as it sounds like it might not be sensing water level increase and switching pump on at the right time. (Don’t ask me why it works on wash though.)
Mike.July 1, 2011 at 10:40 am #354535expertcat
No fault codes this time
July 1, 2011 at 1:12 pm #354536leavemetogetonwithit
expertcat wrote:Sat there and watched within 10 mins of drying operating water appears in bottom of inner drum and no drain pump running.
It should be triggering the drain pump to cut in. Not sure whether pressure switches controls this or if it’s just timed. Have you got service manual? It’s on mediator.
Mike. -
