Zanussi ZJD1219 Dryer stops mid cycle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi ZJD1219 Dryer stops mid cycle
  • #53002
    dmajohnson
    Hi there
    I’m new here so please be gentle; I’m also a computer man not an appliance man so feel free to make answers as patronising as necessary 😀 .
    Basically I have a ZJD-1219, the dryer stopped working a couple of weeks ago with E20. I read these forums which suggested replacing the inlet valve, which worked!
    A few weeks of working ok and the dryer now stops intermittently mid cycle, I get no error code. If it’s got 1hr 45mins remaining for example it immediately drops the timer down to 1min then stops.
    Could the condensor need cleaning or something? if so, where is it and is it hard to do?
    Ta
    #313960
    TheSpinDoctor
    Re: Zanussi ZJD1219 Dryer stops mid cycle
    Hi.
    E20 is a drain issue, not a fill issue as replacing an inlet vale would usually require. Are you sure it wasn’t E10 perhaps?
    Has the drain filter been checked?
    #313961
    dmajohnson
    The E20 would happen consistently until I replaced the 3 way valve, once it was replaced the E20 did not reoccur.
    The drain filter is clear and I have already replaced the drain pump a few months ago, prior to this the machine wouldn’t drain. It now completes the wash cycle with no drain issues.
    Would I be wrong to suspect the condensor being blocked? If I do need to clean it, where is it and is it a difficult job?
    #313962
    TheSpinDoctor
    I suspect the condenser is not the issue here as when it blocks it will also usually display E20.
    Do you have a test meter that is able to test the isulation of the product? I suspect this may reveal a fault for you.
    #313963
    dmajohnson
    “Do you have a test meter that is able to test the isulation of the product?”
    I have a multimeter, what should I test? Do you mean isolation or insulation? If so, howd I go about that.
    #313964
    TheSpinDoctor
    Bad spelling. Sorry.
    I meant INSULATION. A standard multimeter cannot usually test for this but you would need to check your multimeter’s literature to confirm this.
    #313965
    dmajohnson
    Assuming that I cannot test the insulation, are there any onther things I can do to diagnose this? Are there other things that it could possibly be?
    (In other words can we skip this insulation test step and assume it’s ok)
    #313966
    TheSpinDoctor
    You could try disconnecting the dry heater & seeing if it still stops.
    That aside, I would strongly advise you get the insulation tested as this often shows up faults. If you cannot do this, it’s engineer time.
