Zanussi ZJD1219 w/dreyer e10
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZJD1219 w/dreyer e10
  • #41256
    alro
    Hi gents
    have a w/dryer that faults e10 on dyer prog machine has clothes wetter than they went in as disc says its a valve promblem its fills with water to condense the steam heaters & fan ok but it has no blockage to pump any ideas
    cheers alan
    #269296
    lerch
    Re: Zanussi ZJD1219 w/dreyer e10
    e10 I think is triple valve fault.
    #269297
    geoff1
    Hi Alan
    It may be advisable to check the condensation chamber for blockage as the pressure system looks for increasing water level at begining of drying cycle. If it does not detect this after 10mins the machine will abort. Chamber is fitted between fan motor and tub back right hand corner. Be careful to make note on how sensor in rubber pipe is fitted. must be refitted the same way ( caught once never again).
    Geoff
    #269298
    Solenoid coil on dryer valve seems particularly unreliable, can go o/c and shut down when warm.
    Mike.
