Zanussi ZJD125 washer dryer conditioner not washing through
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZJD125 washer dryer conditioner not washing through
  • #85362
    Washdisher
    Soap drawer is clean and siphons when removed and filled with water.
    Holes in top of soap box are clear.
    On second part of second rinse, incoming water reduces to a trickle coming from directly underneath the diverter above the soap box. I assume the channel is blocked or perhaps the diverter is damaged or sticking. I did notice that the diverter didn’t seem to be moved into a different position for the conditioner part of the rinse, but I have to admit, I don’t know if it should anyway.
    I wanted to get the soap box out to strip it and examine, but after having removed the rear outer case, two screw from top of soap box, released top hose, channel to condenser, removed wiring from behind soap box and released two tabs from the front of soap box it still did not want to budge. I tried removing the front panel to see if this would help but that was equally difficult. I must say, I do struggle with old Zanussi washer dryers. Any tips guys?
    Derek
    #428454
    Re: Zanussi ZJD125 washer dryer conditioner not washing thro
    It’s an old girl you’re messing with. The cranky dispenser linkage subject to all the wear and tear and hard water limescale buildup making it impossible to correctly set the fab conditioner flow.
    Besides, what’s the need for fabric conditioner these days? Time to educate your customer about modern attitudes toward that gloopy c r a p!
    #428455
    Washdisher
    Hi Martin,
    You’ve met my customer then? Wasn’t aware of the concerns over toxicity – I too need educating. Is there a link you can recommend?
    Derek
    #428456
    Washdisher wrote:Is there a link you can recommend?
    http://www.ukwhitegoods.co.uk/help/fix- … ssues.html
