Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Zanussi ZK87-46EF Fridge Freezer
- This topic has 10 replies, 3 voices, and was last updated 20 years, 3 months ago by
lad25.
December 19, 2005 at 9:52 pm #14169
lad25
Participant😕 Seems like a common form of alarm clock this ……
was woken up in the night by the beeping and all three lights were flashing did a reset and went back to bed only to be woken up again . Checked the fridge and the freezer and both are normal temperatures . Manual says its a major fault ? Any ideas ? Unit approx 4 years old but it good condition .
This is the manual for the unit.
http://www.serviceforce.co.uk/pdfs/U04068.pdf
lad25 ❓December 19, 2005 at 10:45 pm #158435Dave_Conway
ParticipantRe: Zanussi ZK87-46EF Fridge Freezer
If you read this thread lad25:
http://www.ukwhitegoods.co.uk/modules.p … ic&p=63333
It’s virtually the same product (controls are identical).
December 20, 2005 at 12:02 am #158436lad25
yeah I read that but my unit is working as normal just wondered if there was a simple fault that caused the alarm to go off …. one thing I did notice was that when I took the bottom facia off there was a lot of muck blocking the vent , would this cause an alarm ? ❓
December 20, 2005 at 8:17 am #158437Dave_Conway
lad25 wrote:one thing I did notice was that when I took the bottom facia off there was a lot of muck blocking the vent , would this cause an alarm ? ❓
More than likely yes 😀
December 20, 2005 at 10:09 am #158438lad25
the update so far looks good , no more alarm , thanks for the advice . 😀
January 2, 2006 at 1:37 am #158439equinox
Have something similar – same problem (not checked vents). Problem happened a few times, works fine after reset, after a few months of this it started to make a noise (kind of permanent high pitched sound when fan/compressor is on). Not sure if it is the fan that could do with replacing or the sign of something more serious. No restart needed for some time now though.
Anyone have any ideas?
January 6, 2006 at 3:54 pm #158440lad25
just when you thought it was safe to go back in the water ……….beep beep beep beep …..
This is now driving me mad the fridge has started beeping again everything seems ok freezer working fridge working , anythought what could be causing this beep beep beep …….
ps Ive started to hear this beep when Im not even in the house !
lad25January 6, 2006 at 5:36 pm #158441Dave_Conway
I’ve been reading some info on this and there are two audible alarms, one is the door open alarm and the other the high temp alarm (freezer over -12 for more than 45 mins)
With either, one of the three lamps should also be flashing, if that is not the case then I think you may have an electronics problem (the main control PCB).
Are any of the lights flashing at the same time as the alarm is sounding ?
January 6, 2006 at 8:30 pm #158442lad25
yeah when the alarm is flashing all three lights are flashing at the same time , according to the manual this is a major fault … 😥
cheers
lad25January 7, 2006 at 12:35 am #158443equinox
Take the fascia off at the front and give it a good clean – you’d be surprised at what’s under there.
July 2, 2006 at 1:02 pm #158444lad25
Well after a few months of non beeping its returned and now the freezer keeps defrosting , fridge seems ok . When I unplug it and restart the freezer starts to work again , its now the second time its done this , any ideas what it could be or is it engineeer time ?
ps any in the ne232xr area ?
