Zanussi ZKC5030 cooker no heat in main oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Zanussi ZKC5030 cooker no heat in main oven
  • #54110
    SPACEKID
    I havr a Zanussi ZKC5030 cooker. It has tripped main fuse in fusebox. When I reset the trip. The lower oven does not heat up. The fan rotates and I think the fan element may have gone. Does the oven have anymore heating elements other than the circular fan element ? – Thanks
    #318438
    Re: Zanussi ZKC5030 cooker no heat in main oven
    Hi spacekid,
    Bit of an odd one that as it seems that only this element fits this model. 😕
    Anyway, if you’ve no heat on the main fan oven function it will, in all likelihood, just be the actual fan element. I’m not familiar with that cooker but you will generally have a maximum of three elements in a fan oven, a grill element which can be dual purpose and serve as a top oven element and a base element if the oven has that functionality.
    Neither of the other one or two are related usually to the fan element at all.
    HTH
    SPACEKID
    Many thanks for your help.
