Re: zanussi zkc5540xs 943206179 grill hinge
as far as i can tell its under the side panel i got a call to a similer cooker using the same part but when i went to fit it a realised it was all gas not dual fuel as the customer said. no access from under the hob or from the back but the screws for side panel are on the inside so need the back off problem with me is the grill gas pipe goes through a hole in the back cover so had to pass the job to gas safe engineer hope this helps
