Zanussi ZKG7125 (914604042 01) W/D Powering Up Fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZKG7125 (914604042 01) W/D Powering Up Fault
  • #98765
    jontymox
    Good afternoon,
    The above washer/dryer has an obscure fault in that it takes around ten seconds for the display to power up/show digits from selecting a programme.
    On other occasions it will not power up at all, and the customer switches it off at the socket, and leaves it for an hour or two, and then it will do the same as above, or not power up.
    I’ve had a good look at the wiring harness from the supressor to the main board, and Ohms resistance tested the cables as best as possible.
    I decided the fault must lie with the main board, so renewed it, along with the mains suppressor, which I noticed had a crack in it’s casing and may have been breaking down intermittently.
    However, as the fault remains, any assistance would be welcome!
    jonty
    #473727
    timdowning
    Did you insulation test the dryer & wash heater? As always low insulation can cause display issues…
    #473728
    timdowning wrote:Did you insulation test the dryer & wash heater? As always low insulation can cause display issues…
    agree had that a few times. window lights up but no display
    disconnect dryer elements and all comes back
    jontymox
    Faulty dryer element on order!
    Many thanks for your insight.
    jonty
