Zanussi ZKG7145 914604048/01 washer dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZKG7145 914604048/01 washer dryer
  • #93957
    dunston
    This is a continuation of a previous repair and post.
    We replaced the Dryer PCB Assembly 1324478203 and it worked in a few days.
    However now when you select tumble dryer;
    Fills through correctly thro. dryer valve into condenser.
    Fills to active pressure switch.
    The dryer motor turns once only.
    Then the wash side of the fill valve opens and fills to first level, aborts program and displays 1.Diagnostic check shows E66.
    We have check for earth faults. Cannot find any.
    Can anyone help.
    #456024
    kaibart
    Re: Zanussi ZKG7145 914604048/01 washer dryer
    Try disconnecting the dryer element then run it these give loads of weird faults
    #456025
    dunston
    Tried disconnecting dryer elements and wash element – same problem.
    On wash it fills and washers for a couple of minutes then aborts.
    Displays 1. Stops full of water.
    Diagnostic shows E66
