Zanussi ZKi 245 washer dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZKi 245 washer dryer
  • #78463
    winker
    Have fitted a new configured board as the original had a small burn out component and would not light display.Took all precautions and meggered components and continuity tested as well.Did find low insulation on dryer heater but not enough to trigger house trip.
    The display lights up and selecting cycles shows different cycle times but pushing start purges pump and instead of filling the machine defaults to flashing start light.Now I have disconnected heater dryer as its low on insulation and can trigger a default so do you think by leaving it disconnected this will cause the fault or is there something i have missed.Not sure on this model how to access diagnostic mode and retrieve fault code if any.Nothing comes up on the panel fault code wise.
    #405783
    Re: Zanussi ZKi 245 washer dryer
    Give me your email address and I’ll send you the relevant guff. 😉
