Zanussi ZKT631DX Hob
  • #54357
    A1TEC
    Got the above 4 zone hob showing error 3.
    Any ideas what error 3 is indicating before i go out to this one.
    Also any service info would be appreciated.
    cheers
    John.
    #319333
    Seamy
    Re: Zanussi ZKT631DX Hob
    E3 is a voltage imput error, can mean over voltage or under voltage detected. If customer powers up hob for first time you will get E3. If customer shuts off power at cooker control on wall you will get E3 when power is restored. Bad cable connections or links loose in terminal block would give this error if customer finds its coming up in use rather than when turning on hob at wall control.
    #319334
    A1TEC
    Thanks for that seamy, can the error be cleared and how do you do that?
    cheers
    John.
    #319335
    A1TEC
    Can anyone help a little with more info on this one?
    cheers
    John.
    #319336
    Seamy
    You should have e-mail
