Zanussi ZNG1120M
  • #77221
    DaveH53
    My daughter has the above machine which is less than 2 years old and as far as I can determine the bearings have failed or worse.Is it worth attemting a repair or is it likely to fail for another reason as soon as its been repaired. How much would a professional repair cost please?
    David
    #401464
    Re: Zanussi ZNG1120M
    David….time to cut your losses….it is beyond economic repair…..cheap Chinese made rubbish!
    #401465
    DaveH53
    I have taken the top off and the drum does split. I would like to dismantle it just to see whats happened and wondered whether anyone has taken one of these to pieces. looks like the only way is to lift drum out from the top or can you do it from the front?
    Any advice welcomed.
    David
    #401466
    DaveH53 wrote:looks like the only way is to lift drum out from the top or can you do it from the front?
    The drum comes out using a combination of both the top and front panel removal. Do bear in mind that the bearings and water seal are NOT available as separate items. The rear drum half (part no. 4055210779) is the only option at the staggering cost of £175.
    Happy New Year! 😀
    #401467
    Seamy
    Bearings & seal are available separately, you would be very lucky to get away with just needing these, as sometimes spider (shaft) also needs replacing..
    4055066726 Seal
    4055130274 Bearing front
    4055066742 Bearing back
    http://shop.electrolux.co.uk/product/40 … um+Bearing
    #401468
    DaveH53
    Thanks Seamy
    The bearings and seals are standard engineering fare but not sure whether the shaft is up to it and not sure of quality of replacement spiders. The first Zanussi we bought lasted over 20 years and my daughters lasts for 2! Its a shameful really. There should be minimum quality standards to stop all the waste. I know it would mean more expensive machines.
    David
    #401469
    Seamy
    Spider that you get as a spare should be actually be better than the original one in the appliance. There is a slight difference where the seal runs, they tend to last longer than the original one fitted. You may get away without having to replace the spider though if you want to try just bearings & seal. If its been really noisy though & bearing housing in rear tub is damaged or spider shaft damaged its not worth doing as Martin advised.
    Note.. Model is ZWG1120m if you are looking for spares.
    #401470
    captaincaveman1
    These machine’s have never seen a Zanussi factory. Mainly were sold through Comet as “The manager’s special” and as the creator of this thread said it is shameful that this deception is allowed as he bought the machine for his daughter on the basis of the good service of his proper Zanussi machine. I know Electrolux need to try and compete with the like’s of Beko but ruining the Zanussi reputation isn’t the way forward. If you want a proper Zanussi make sure it has the rectangular filter cover on the bottom front right corner.
    #401471
    captaincaveman1 wrote:it is shameful that this deception is allowed as he bought the machine for his daughter on the basis of the good service of his proper Zanussi machine.
    The “rebadging” of machines has been practiced for decades sadly and in this case I hardly think the OP would have bought it under its ‘actual’ brand known as Wuxi Little Swan as illustrated below….
    #401472
    Seamy
    captaincaveman1 wrote: If you want a proper Zanussi make sure it has the rectangular filter cover on the bottom front right corner.
    This Chinese made Little Swan ZWG1120M rebadged Zanussi has a rectangular filter at the bottom right hand side. (I presume you mean not in the kickplate)
    Best to look at the sticker inside door, if it says manufactured in PRC then its Chinese.
    I don’t mind working on the ZWG1120 & ZWG1140, its the Vestel manufactured one that is torturous.
    To be honest Zanussi has moved to the lower end of the E’Lux brand as Bendix has been dropped.
    Electrolux & A.E.G machines now on offer with 5 year warranty are decent enough.
    #401473
    captaincaveman1
    Your right Seamy not on the kickplate the proper Zanussi has no kickplate just the filter aperture.
