Zanussi ZOB330X Extremely loud fan
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Zanussi ZOB330X Extremely loud fan
  • #98853
    CPTHFC
    I have the following oven
    Make: Zanussi
    Model : ZOB330X
    Prod No 949712892-05
    The cooling fan (I believe) makes an extremely loud noise whilst the oven is in use. The noise is a loud rattling at a fast pace that eventually slows and stops. This happens every 10 minutes or so when the fan oven setting is used. It can be temporarily stopped by slamming the door of the oven.
    What replacement part do I need? Is this a job an amateur could do?
    This has been a problem with the oven for a few years now and the oven is about 9 years old.
    Thanks in advance
    #474033
    provided it only does it on the fan oven setting its more likely to be the fan inside the oven and not the tangental cooling fan
    so part you need most likely is
    https://shop.ukwhitegoods.co.uk/4055015707-oven-fan-motor
    but you must acertain this is correct by yourself
