Zanussi ZOD690X double oven – How many KW pls?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Zanussi ZOD690X double oven – How many KW pls?
  • #47723
    GillM
    A customer has brought to France an English oven as above. The only information I can find is that it is Ecomomy group A.
    Also an Electrolux EHS60210P ceramic hob for which I am unable to find KW values too.
    Can anyone out there who has access to more technical specifications, please tell me what the maximum KW is that these items are likely to pull if both on at the same time (worse case scenario).
    I ask because the electricity going into his house is 9KW……. (a normal amount for France) and it seems a possibly that these could trip the main incoming fuse!
    He may need to upgrade to 12kw.
    Thanks in advance for any information you are able to provide.
    #294371
    Re: Zanussi ZOD690X double oven – How many KW pls?
    Can you give us the PNC number from the rating plates.
    #294372
    I can’t find either of them, Iadom.
    Neither of those model numbers come up on my TDS either, PNC number is our only hope. 🙂
    #294374
    GillM
    Thanks for checking this out, I really do appreciate it – is there any additional information I can provide for you to make it easier? I’ve checked everywhere I could think of on the WWW but without any luck!
    #294375
    Can you not find any rating plates on either ? look underneath the hob and inside the door, back and lower edge of oven compartment.
    EDIT. Using a * wildcard I have found some info. No sign of a ZOD690, there is however an 890 plus around 20 other varients.
    I will send you what I have found. 🙂
    GillM
    The problem is that they are still in their original boxes and still in the UK. They are/were to be fitted into the new kitchen of their holiday home here in Brittany next month.
    The customer is here in France and the appliances are in Portsmouth……
    #294377
    don
    Both are new models 😉
    The Zanussi ZOD690X has PNC944171468 Pro corner lists it by PNC. Trouble is there is no download anywhere of the instruction manual for the total kw rating, not even at Service Force. A phone call to Zanussi direct on 08445 612612 may be the only answer.
    I had better luck with the hob though 😀 Product no. 949592910 looking at the tech spec here it appears that the total rating is 7.1kw.
    HTH
    Don
    #294378
    GillM
    Many thanks everyone for your kind advice, especially Jim who very kindly sent me documents via email!.
    I have now found out that the Zanussi oven is 5.3kw, and (thanks to Don) that the hob unit is 7.1, making a total of 12.4kw if they are both switched on together.
    So our client has a 5 bed holiday home over here with an incoming (single phase) supply of 9kw, from which he’s going to run a water heater, electric kettle, 9.5kw electric shower, washing machine (cold fill), tumble dryer etc, etc in addition to the above ……? 😯
    I think he needs a rethink …….. 😆
    Thanks so much for all your advice, it’s really appreciated and will save our client a lot of problems with blown main incoming fuses!
    #294379
    don
    He could always if it`s possible replace the instant shower with a power shower assuming there`s plenty of H&C on tap and go for a French gas hob if at all possible 💡
    don
