Above zanussi oven has electronic temp.selection as apposed to thermostat.Temp. appears to reset to 150c (default) partway through cooking program.Found low earth resistance on base element when hot so disconnected temporarily but fault still persists.
May guess it is one of the two boards but which one ?There is a power board on top of the oven but i’m leaning towards control module on fascia ?
Anyone with any thoughts or experiance of this !!!! service code 94971819900
it is a toss up on this one
both board contain software
have you had a look at the power board caps to look for bulging ones. dirty power supply could cause the chips to crash
any fault codes coming up?
have looked at tech but does not seem to have any test procedures etc. but if you would like it let me know
if I had to take a guess, as long as the power supply looks ok then I would assume all the setting software would be in the display board which makes it more likely but far from certain
