Zanussi ZSF 2450 leaking and won’t switch off
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Zanussi ZSF 2450 leaking and won’t switch off
  • #57185
    roehampton
    Hello all,
    My tabletop Zanussi cut out last night, and tripped the RCD switch. When I reset the RCD switch and switched it on, it resumed pumping and wouldn’t switch off until I pulled the plug. It was also leaking from underneath (NOT the fill hose).
    This morning I reset it and started it on a simple rinse cycle. It filled normally, but then started leaking from underneath (seemingly front lefthand corner), and again wouldn’t switch it off until I pulled the plug. With the plug out, I tilted it back a little to look underneath and lots of water ran out of the back of it.
    Any ideas? It is only 13 months old. I would really appreciate any help as I do rely on this DW quite a bit, it’s on once a day on average and has been problem-free up to now.
    #330174
    Swilter
    Re: Zanussi ZSF 2450 leaking and won’t switch off
    Hi, did you find a solution to this?
    I have exactly the same issue with the same model.
    #330175
    Swilter wrote:Hi, did you find a solution to this?
    The only sure way in locating the leaks is by getting hands on. Power unplugged, lay appliance on its back (only) and remove the bottom panel. Signs of water leakage should be apparent once that panel is removed.
