Zanussi ZSF 6150 D/W
  • #14623
    reaper
    Pnc 911915081/01
    Goes through programme but no heat.Heater checks out OK. Large thermostat on sump and two pressure switches on side any clues?
    Just dipping my toes into dishwasher repairs after laying off them for ten years they were bad enough then but now they seem to have a whole lot more problems and you have to remove the bases.
    #160184
    Re: Zanussi ZSF 6150 D/W
    Big file steaming through the ether even as I type……..
    reaper
    Thanks Chris.
    Wow! I’ve perused this document the machine is one with 4 contacts to the ntc -an inbuilt turbidity sensor,(an infra red feedback device to tell you how dirty the pots are) plus the temperature sensor- I’m impressed.
    I’ve seen this question asked before on here and wondered what the outcome was, it would nice to get the feedback as it might be a common fault. I bet theres a Zanussi engineer who’s had loads of these and fixed them in 10 minutes.
    Suspect main Board (relay) or ntc device.
    #160186
    barryfast
    reaper wrote:Thanks Chris.
    Hi got the same prop the p/r s/w near the front feed,s the heater connectins1&3 cloesd wen full a1 relay on maine board one on order
    part No1527832-70/1 £73.13 + ? will let you know the out come
    barryfast ❓ 😯
