went to this dw- no heat . checked module ,burnt track on heat relay found and repaired. nice easy one , (or so i thought ) tested machine , now nothing doing. 5 volt to module but no display from module, checked ribbons for connection all seem ok. what have i done ? machine was working/ just no heat . is it possible to corrupt a board by repairing a dry joint. done many of these with no problem-
just wonder’d if this rings any bells???
clive.
hi guys
went back this am to double check- youre right , i reversed the connector as you both said!! sometimes you cant see the bleedin obvious, even when it stares you in the face. DOH!!
clive
