Zanussi ZSF6161 flood reset
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Zanussi ZSF6161 flood reset
  • #43485
    frankie346
    my Zanussi ZSF6161 (911916240/02) has stopped and displays the error code i30, according to the manual this means that the flood protection feature has activated and disabled the water inlet valve, does anybody know how to reset this?
    I have tried searching the forums but cannot find any reference to this error
    many thanks
    #277391
    Re: Zanussi ZSF6161 flood reset
    There are two flood protection systems on this appliance – a float switch in the tray under the machine and a cut-off pressure switch as part of the fill matrix.
    If the float switch is activated, you can pull the plug and simply tip the machine to one side. If water comes out, you have a leak. If it doesn’t, the pressure switch system will be at work. This probably means that there is a blockage in the fill matrix, diverting air from the level preesure switch to the overflow one. Strip down and investigation required.
    Stay safe, power off before removing any panel.
    frankie346
    I tipped the machine to the side and water came out, so I guess I have a leak, it turns out that it is still under warranty so I will leave it to Zanussi,
    Thanks for your help
    #277393
    RHrepairs
    i have the same problem…..i30, no leakage, the antiflood device works perfect, took off fill matrix and cleaned it out. Check pressure switches for blockages and nothing so could it be the board?
