Zanussi zt695
  • #40275
    franz
    Won’t fill with water – valve buzzing but meters o.k – is this a problem with overflow assy attatched to valve or is something else causing problem .
    Franz
    #265402
    rogue_element
    Re: Zanussi zt695
    hi
    remove cover from valve you then should find a small pink pipe , remove bung from end if water drains out done. always a good idea to look at side tank for blockages
    rogue
    #265403
    franz
    Re: Zanussi zt695
    thanks Rogue – will try that – sorry for taking so long to reply
    Franz
