Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Zanussi ZT695 error message
- This topic has 7 replies, 3 voices, and was last updated 21 years, 1 month ago by
themilkman.
March 12, 2005 at 7:10 pm #8436
themilkman
ParticipantHi all,
have searched the forums but can’t find anything relating to this model.I could do with some help please!
The dishwasher stops during any wash cycle leaving the washer with water in it and starts flashing the third button.Having looked through the instruction manual this fault comes under the SYMPTON colum as a “general fault”.I’ve switched on and off put it through a rinse and hold cycle, which clears the water and completes its cycle normally
Have tried this loads of times but will not clear the fault.
Lucky enough for me the dishwasher is two and a half years old so is just out of its warranty 😯I’d appreciate any help with this one, thanks
March 12, 2005 at 8:43 pm #128632Penguin45
ParticipantRe: Zanussi ZT695 error message
Temperature sensor, or associated circuits. Computer not detecting temperature rise within specified periond.
Awkward one to sort – engineer time?
Penguin45.March 12, 2005 at 9:06 pm #128633themilkman
Thanks for the quick reply,
does this look like an expensive job?Is it a diy or a definite engineer?
Just can’t believe a £500 dishwasher knackers up 6 months after its warranty runs out.
Guess I’m just lucky that way 😆March 13, 2005 at 12:26 am #128634Penguin45
The thermistor is p/no 50273371-00/0 – £8.02 plus the usual, spares@ukwhitegoods.com will get it for you if you wish.
However, confirming the diagnosis is the critical bit. If you can’t do that, time for an engineer. Check repairs@ukwhitegoods.com or Directories for a UKW repairer in your area.
Do nothing yourself without pulling the plug first.
Penguin45.March 13, 2005 at 9:25 am #128635themilkman
that sounds better than expected.Is this thermosister behind the door panel or is it located at the rear of the machine and are there any exploded diagrams of this model available.Thanks for all your help so far 😉
March 13, 2005 at 6:48 pm #128636themilkman
I’ve had the front panel off today and couldnt see anything wrong nor could I see any thermal fuse or similar.It’s looking like taps off, pull out job,screw drivers galore and fingers crossed.
Anybody got a drawing of where I could find the thermistor if not then its engineer time 😥Thanks
March 13, 2005 at 10:33 pm #128637Dave_Conway
Sorry milkman, technical info isn’t available on most appliances except appointed agents and trade guys who pay for such info 🙁
March 14, 2005 at 7:07 am #128638themilkman
Ok
fair enough, thanks anyway
its a miracle its started working again, must have disturbed something maybe a loose wire 😮 -
