Zanussi ZTE 285 – won’t turn on
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Zanussi ZTE 285 – won’t turn on
Viewing 2 posts - 16 through 17 (of 17 total)
  • #401578
    Re: Zanussi ZTE 285 – won’t turn on
    From the manual, here’s the disassembly of both versions…
    I will tell you, this is NOT an easy dryer to strip down by any stretch.
    You start with the worktop off, then top crosspiece, then fascia, rear heater panel, side panel… then you get to the door switch and a bunch of other stuff. It’s rather tight looking for space too, so expect to get a cut or two.
    Good luck and, I wouldn’t look forward to stripping that down, even for an experienced engineer it looks like a proper pain in the…
    HTH
    Zyphrax
    Zanussi sent me the service manual.
    I was happy to discover the following section:
    11 NO ACCESS TO DIAGNOSTICS PROGRAMME
    11.1 No LEDs on the display board light
    It contains a nice workflow with clear steps to check.
    That will keep me busy for quite a while.
    Thank you for your time and help!
    You can close this topic (for now ;))
