Re: zanussi zuq875x
hi, on these particular ovens, the fan should blow above the grill door, over a slightly angled deflector plate, fixed onto the top of the grill door. pt/no 3113533032. this then causes a venturi effect, sucking air up from the bottom of the main oven door, between the inner/outer glass, and then up through the top oven door , the same way. check to to see if the deflector plate is still on, also make sure there is no obstruction in between the inner/outer glass doors on both ovens. hope this helps. these should definatley be cool enough to touch without injury.
TELL..
