zanussi zwd 1417 E35 error
  • #71753
    slyp98
    so this is showing E35, which relates to the inlet valves , (fine) the wiring (fine ) the pressure switch (fine ) leaks etc (none ) so there is carbon dust on the power supply area of the board which i have seen all too often , so is it down to the faulty board again? how can this happen constantly and not be damaging the valves switches wiring etc are the boards so cheap they just pack in with the slighest over voltage ?? grttin sick o his crap , i replaced 5 boards in the past 2 months , no problems with any components !
    #382187
    captaincaveman1
    Re: zanussi zwd 1417 E35 error
    Its a board fault yes but worth checking the door switch for discolouration on the side (cream door switch but goe’s brown in the centre if its on its way out) as this can spike the board . I take it you dont mean you’ve replaced five boards on this particular machine though?
    #382188
    slyp98
    no no just in all brands , h/p mostly
