product no. 914604002/00
having a bit of a nightmare with this one
original problem dryer not working so with guidance from bob hope, problem solved.
customer put washer in trailer to take it home, gets home plumbs it in, dryer works great but washer has stopped working. the symptoms are. Door locks then does compulsory drain, door opens, then nothing. any help appreciated.
Darren
first of all check the dryer heaters for earth leakage as they give strange symptoms when there is and earth leakage, and considering the dryer has been out of action its the first port of call if i was you.
thats provided the customer has reconnected the appliance correctly.
