zanussi zwd 1471s washer dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum zanussi zwd 1471s washer dryer
  • #81128
    spencer123
    Hi machine was giving a error code 40 after a while during was. But when I pressed start/pause and skip buttons together it gives e41,The machine went through a wash later today,But when Iwent to do another wash its coming up with a error code A11 any ideas , :rolls:
    #415400
    Re: zanussi zwd 1471s washer dryer
    E41 a door lock error, E11 a fill problem. I would ignore both and instead suspect the dryer element has an earth leak causing these random unassociated errors.
    #415401
    spencer123
    Hi Martin how do you test it for a earth leak can you use a multimeter cheers,
    #415402
    spencer123 wrote:Hi Martin how do you test it for a earth leak can you use a multimeter cheers,
    You need a 500dcV Insulation Tester as a basic requirement for earth leakage testing.
    #415403
    spencer123
    HI Martin i couldnt get my hands on a insulation tester,but when i opened up top off machine the heater is disconnected
    #415404
    Check out the E40 error now then : The door lock.
    #415405
    spencer123
    Hi martin even if it locks when you select a program?
    #415406
    Hmmmm? OK then check out the water heater for same insulation issues as the dryer heater. Except disconnecting the leads will show an E60 error or some such IIRC? It needs meter testing.
    #415407
    spencer123
    Ok martin will try.Will have to get a meter to test thanks for your help
