Zanussi ZWD 1471W Error Code E36
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZWD 1471W Error Code E36
  • #46815
    Turbo
    This washer dryer is as new, dryer side never been used the pressure tubes are ok.
    It fills for about a minute and then cuts out. If you drain the water out it keeps cutting out but once the water has gone it will spin ok.
    Any suggestions please.
    Graham
    #290991
    silverbroom
    Re: Zanussi ZWD 1471W Error Code E36
    Hello Graham,
    Just back from a cycle run up the glen (braw nicht oot) E36 error quote, “sensing circuit on anti-boiling pressure switch 1 is defective.
    Main board defective.
    Machine responds with stopping cycle with door locked, hope this helps.
    silverbroom
    #290992
    Graham, did you manage to sort this one out ? I have one doing exactly the same.
