I had a small leak and turned the machine on its side to get a closer look. In doing so I got water where it shouldn’t go and subsequently found a burned resistor R119 on the PCB.
I don’t know if there is any other damage and I can’t tell what value R119 should be. The local relays all seem to be operating fine when I applied 12V to their coils.
Can anyone advise? I’d like to start by replacing this mystery value resistor.
E51 = PCB fault current leakage from motor or from wiring.
Check if there was damage to motor loom or plug at motor, try replacing said resistor but i’d reckon you need a new P.C.B.
Power off of course when working on or doing testing to appliance.
