Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › zanussi zwd 1627
- This topic has 10 replies, 4 voices, and was last updated 15 years, 11 months ago by
mowerman80.
May 12, 2010 at 4:55 pm #54567
mowerman80
ParticipantHi got this machine no power getting to the dryer elements ,tested the stats all ok so could it be the square conrtol board just behind the fascia as the wires to the elements come from this board ?
May 12, 2010 at 5:24 pm #320178Seamy
ParticipantRe: zanussi zwd 1627
Not sure of the model, PNC would help. If its a ZWD16270 there is a dryer pcb, check communication cable & connectors between both & dryer heater resistance to earth first.
May 12, 2010 at 6:34 pm #320179mowerman80
hi pnc number is 914604030/02 ,it has the dryer pcb with 4 black boxes inside . i have checked the wire connectors on the board and they seem ok. connect distribution dont seem to do the part so is this part direct from zanussi?
May 13, 2010 at 9:28 pm #320180leavemetogetonwithit
379 26 33-00/4 pcb assembly drying £41.70 direct from lux.co.uk
Not saying that’s what’s wrong though.
Mike.May 24, 2010 at 2:59 pm #320181mowerman80
Ok ive changed the dryer board and its still not getting any power to the dryer elements. Think im gona cut my losses on this before i go broke unless anyone has any suggestions?
May 24, 2010 at 4:13 pm #320182Martin
mowerman80 wrote:unless anyone has any suggestions?
Entering into the diagnostics programme can be an effective way of sussing out what’s wrong in this case. I suspect you may not have ventured this simple procedure though?
If you send me your email address request (mine is listed below by the way) I can send you full details. 😉
May 24, 2010 at 10:13 pm #320183leavemetogetonwithit
Did you try doing a search? There’s quite a lot comes up in response to “Zanussi AND drying” select: trade tech enq. only.
Here’s just one, zanussi not drying
Mike.May 24, 2010 at 10:19 pm #320184leavemetogetonwithit
Or this one,another zanussi not drying
Mike.May 25, 2010 at 7:58 am #320185mowerman80
Great info will go back and try that. This is why this site is so good ,thanks.
May 25, 2010 at 3:49 pm #320186mowerman80
ok went back today and sure enough one of the wires on the ntc had pulled off. Bad bit is after putting a new plug on the end and testing the ntc it still diddent work 😥
May 25, 2010 at 9:00 pm #320187leavemetogetonwithit
Continuity from lower ntc to board terminal? Sure it didn’t pull out again when you lifted machine back?
Using original board or new one or tried both?
Seems unlikely there’s a second fault when the “obvious” one was so clear.
However, would be worth doing another search of the forums. Water valve coil is a favourite to fail. There’s a hint in there of pressure switch problems too. Also what about diagnostics, as Martin suggested.
Mike. -
