Zanussi ZWD 16270 W ends cycle early and releases door.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZWD 16270 W ends cycle early and releases door.
  • #54493
    SteveATY
    Shows no error codes in display.
    Program machine and it starts normally. After wash cycle (water is heated) the machine empties of water and does gentle spin. When the machine comes to do its rinse it just reverts to ‘end’ and the door releases. The machine then will not take a further program for a couple of hours. Once a few hours passes the process can be repeated.
    Any clues,
    Steve.
    #319812
    Re: Zanussi ZWD 16270 W ends cycle early and releases door.
    You’ll need first of all the enter the diagnostics sequence to find the last error code. No error codes will possibly point to a fauly main board anyway, but earth leaks on dryer elements, open circuit dryer inlet valve coil can have a similar effect showing no error code. An E8? or E9? error shown on diagnostics is usually the main board faulty by the way. 😉
    Rubbish machine they are though IMHO…. :rolls:
    #319813
    SteveATY
    Would anyone have the diagnositc PDF for that machine?
    I tested the dryer and it appears to work. However the wash cycles all cease to proceed after just a few seconds (unless the machine is left a couple of hours)
    Steve.
    PS Agree with Martin on the quality of the machine – rubbish! The module is £160 odd which pretty much means a write-off.
    #319814
    Email on its way to you Steve, let me know if you don’t receive it though.
    #319815
    When Martin mentions earth leaks on dryer elements he means anything below FORTY MEGOHMS. (Not what would normally be considered a significant earth leak. Won’t stop dryer working normally!) Thus it is written in the service manual if you can find it. And it has been the source of much grief. Disconnect element and see if washer will then work normally.
    Mike.
