Zanussi ZWD 16581W
  • #56804
    johnnyhoz
    This machine starts by draining then cuts out, No error codes appear, and the start/pause flashes continuously. The dryer programme works fine. Can’t see any mention in the known error codes.
    Any ideas please
    John
    #328891
    Re: Zanussi ZWD 16581W
    Check the usual Johnny, Heater, Inlet Valves, Motor/Brushes and don’t overlook the wash pump too! 😉
    After all that and you can’t find anything wrong then it’s out with the PCB for a visual. 💡
    #328892
    johnnyhoz
    Cheers Martin
    #328893
    Check for insulation resistance below 40 Megohm on dryer element. If it’s not that, try same test on wash element. (See service manual pp. 84 & 86 or thereabouts.) Washer should work OK if you disconnect dryer element.
    Mike.
