Zanussi ZWD12270 ERROR
  • #55689
    gadgetdad
    Hi guys, have been called by a customer with a fault on this Zanussi – know nowt about these apart from they are pants !!
    Im told the machine tries to start but makes a click and the start button flashes – door interlock maybe ? If so how do I test one of these types.
    Cheers my dears
    Mitch
    #324768
    aqualectric
    Re: Zanussi ZWD12270 ERROR
    Door interlock or drier element shorting to earth. Unplug the drier element and try the machine again.
    HTH,
    Steve.
    #324769
    gadgetdad
    Thanks for that – will drop by there today – cheers.
    Mitch
    #324770
    gadgetdad
    Hmmm – visited site – tried machine with heater disconnected – same error – tried new interlock – same error.
    Machine takes in water for about 10 seconds then you hear the door click open and the pause/start light flashes green !!
    Module ?? lots of money !!
    Mitch
    ps – didnt disconnect the dryer heater – might this give me the problem even at filling up stage ?
    #324771
    gadgetdad wrote:ps – didnt disconnect the dryer heater – might this give me the problem even at filling up stage ?
    You did’nt take on board what aqualectric told you did you?…..you naughty gadgetdad you!:lesson:
    gadgetdad wrote:how do I test one of these types
    Enter the ‘diagnostic cycle’ may tell all (see KNOWN ERROR CODES).
    It’s important to realise that all these modern electronic heaps of junk do ‘self-check’ their individual components before embarking on any programme cycle. When an error occurs as in this instant, the machine throws a wobbly if (for example) the dryer element is o/c or s/c. Or the motor brushes are knackered, or the inlet valve o/c and so on…….
    Entering ‘diagnostics’ can save time fuffin’ around checking all components and can be done prior to even attempting to move the machine. 😀
    SIMPLES! 😆
    #324772
    jeremy
    http://www.ukwhitegoods.co.uk/modules.p … ic&t=56115
    The problem was the dryer element < 10meg e/ins in all cases , ive had another 2 since exactly the same fault, all 3 customers hardly used the dryer on them.
    Disconnecting the element sorted it, doesnt seem to throw any error when its taken out of circuit so 1 customer said leave it disconnected then, havent heard a peep out of them so all must be good.
    Jeremy
    #324773
    gadgetdad
    Yep, guilty as charged – didnt note that it was the dryer element that was probably suspect – will return with new dryer element next week 😳
    Doesnt actually show an error code ! dont know how to enter diags on Zanussi machines – might it be in the “book of codes” available from here ?
    Ta muchly
    #324774
    don
    gadgetdad wrote:Doesnt actually show an error code ! dont know how to enter diags on Zanussi machines – might it be in the “book of codes” available from here ?
    Ta muchly
    No worries gadgetdad it`s here in the known error codes thread, page three half way down.
    You can purchase the “book of codes” from this link the top one for a tenner is for trade and the £30 version is for the public.
    Don
