zanussi zwd12270w
  • #76521
    tash
    hi went to the above model washer that wouldn’t start the program , door not locking… because of limited access I tried a new door switch first, seemed to cure the problem but now the customer has rang to say its doing the same again intermittently, when I go back ill check the brushes etc but what else should I be looking for?…thanks
    #398675
    Muv
    Re: zanussi zwd12270w
    Did you check the door striker for wear?
    #398676
    tash
    hi yes its ok..thanks for replying though 😀
