Zanussi zwd12270w not starting
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi zwd12270w not starting
  • This topic has 3 replies, 2 voices, and was last updated 17 years ago by pmb.
  • #44208
    pmb
    Hi i have a Zanussi zwd12270w (91460400000) which when put onto any program it pumps for 5 seconds and then flashes the start button as if it is paused but when you press the button it doesn’t respond. I have checked all the obvious things water valves, heater, motor, pump but everything seems fine. Is there a test mode on these machines like the older ones where i can trace the problem to a component? thanks Peter 🙂
    #280195
    Re: Zanussi zwd12270w not starting
    Haven’t I just sent you that info via email, or maybe I’m confusing you with someone else? 😕
    #280196
    pmb
    Hi Martin yes its me but it didn’t have any information on test sequences or how to find the fault should it have?
    #280197
    Oh flip! OK then, if you give me your email address again I’ll send you a whole bunch more on the subject.
