ZANUSSI ZWD12270W WASHER DRYER
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries ZANUSSI ZWD12270W WASHER DRYER
  • #47545
    funkyboogy
    getting e20 when dryer selected,
    works fine on wash progs..
    any ideas …
    cheers ally
    #293775
    helo_75
    green coil o/c on valve is the usuall
    but worth checkin pump function (earlier ones had a toc which cut out when hot) or blocked condenser
    experience points to the green valve coil
    #293776
    MickGeorge
    Re: ZANUSSI ZWD12270W WASHER DRYER
    Blocked Condenser – just done one today with same fault 🙂
    Mick
    #293777
    helo_75
    is there an echo in here?
    #293778
    funkyboogy
    cheers .. is it easy to get to condesor , this wd doesnt split
    ally..
    ps will order valve as well b4 going back
    #293779
    helo_75
    i just replace the coil itself any valve coil will do
    #293780
    funkyboogy
    CHEERS…
