Zanussi ZWD12270W Washer dryer. Cuts out
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZWD12270W Washer dryer. Cuts out
  • #70032
    Latham63
    Machine operates ok,then with about 20 mins to go stops,clicks twice,start button flashes and nothing else can be selected!
    Also the prog display reverts back to the original prog time?
    If left for a day with mains off,will restart,but then stops with 20 mins to go again?
    Suspect the control board. Am I missing something?
    #376821
    Criscold
    Re: Zanussi ZWD12270W Washer dryer. Cuts out
    Have you tried getting into diagnostics to see if a last known error code is displayed + Insulation test on Heaters & Motor
    #376822
    Latham63
    How do I get into diagnostics?
    #376823
    Criscold
    PM your email and I will send you the details
    Colin
    #376824
    Latham63
    Late reply I know.Thanks for the details.The customer cancelled job in the end,after I`d given him a few hints! Suspect it was probably the dryer element.Had quite a few of these causing faults.
