Zanussi ZWD12270W1
  • #91893
    Judehann
    Just bought one of these second hand. Have plumbed it in, using another machine cable as the one with the machine would not let my inlet tap on the pipe open fully.
    Water is going to the machine but the machine is not drawing water in… help!!
    #449647
    1totalshambles
    Re: Zanussi ZWD12270W1
    Faulty inlet valve perhaps can you hear a low key hum at the back where the valves are? Question is, does the machine do anything else at all? What happens if you put the machine on spin only? does the drum go around, does the thing spin? Can you hear the pump coming on, if you pour a litre of water does it pump it out?
    What is the pnc model code as read off the sticky ratings label, begins with 91. If the machine has brushes in the motor and these are worn out, apart from the drum not going round, other strange things can occur or rather just do not happen!
