Zanussi ZWD12270W1 (91460402802)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZWD12270W1 (91460402802)
  • #85747
    Payney
    Hi guys,
    I have got one of these that won’t run through a full cycle. It will do each part of the cycle if set ie wash then stop, set rinse then it stops and set spin but won’t run from wash through spin. It has also been throwing up an e10 fault on fry cycle. Any ideas before I go out please?
    Thanks in advance
    #429457
    Re: Zanussi ZWD12270W1 (91460402802)
    E10 means the water inlet valve needs replacing. A faulty dryer heater may well be the cause of the stopping fault (element having an earth leak).
    #429458
    Payney
    Thanks, I thought as much.
    #429459
    Payney
    I have been out to this and changed the valve which has cured the E10 fault. I changed the dryer element as it was reading high but now the machine starts a dry cycle and if set for an hours dry time will run for 5 mins then the timer drops down to 1 minute then stops. Any ideas gratefully received.
    Mark
    #429460
    Wire to NTC on condenser has come adrift.
