Hope somebody can assist with this problem.
Machine works fine in wash mode, however in dryer mode it stops after a few minutes and the code E10 appears.
User manual points to problem with water supply. Couldn’t see how this could be the cause as OK in wash mode but then saw this model has a 3 way water inlet valve. Would like confirmation that this is probable cause before buying. Is it possible to check valve for possible repair or better just to replace.
Thanks in advance
Pete
