Zanussi ZWD12270W1 washer dryer shows ED1 fault code??
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZWD12270W1 washer dryer shows ED1 fault code??
  • #60915
    EZappliances
    Hi There can any of you Zanussi experts throw any light on this machine. The fault is that it sits there pumping out for about 10 seconds then goes to pause and wont do anything else. Running the on-board diagnostics shows ED1 on the display. I cant find any reference to this code. Would appreciate some guidance to solve this isse as we are not too familiar with this model. Thanks
    #344122
    blackandwhites
    Re: Zanussi ZWD12270W1 washer dryer shows ED1 fault code??
    ED1—Wiring faulty between pcb and wd board.Or faulty wd or pcb.
    Hope this helps.
    #344123
    EZappliances
    tHANKS BLACKANDWHITE But what do you mean by the term WD?
    #344124
    fault is listed as
    wiring fault between PCB and WD board, WD board faulty, PCB faulty
    i assume they mean the main pcb and the dryer pcb but the info is a bit wooly
    time to pull all multiconnections off and put them back to see if its a bad connection
    hope it helps
    martinm
    check insulation on drier element, can give you ed1 if its down
    #344126
    EZappliances
    Thanks for the information chaps. Problem now solved. We replaced the relay board that switches the dryer element and all is well. The dryer element does not seem to have an earth leak. The relay board is available from connection part number 5045174493024 at a reasonable price of £35 + vat hope that may help somebody else in the future.
