hi got a zaussi washer dryer with no heat on the dryer .The dryer cycle
runs right through the fan runs and it takes water in but no supply to the heater and no fault code..any idears
Have you checked the cut out fitted to side of heater tunnel? It is a manual reset version with a red push pin in the middle. Check for continuity through this cut out and if not push pin in to reset. ( cuts power to elements). If this has cut out check for blockages in the condensor etc as air flow has been restricted
hi geoff thanks for the reply yes i have checked this. the machine is only
15 months old it looks as if it has a separate module for the dryer but not sure has anybody else come across this machine
