Just had a look at this machine, it fills, heats and washes ok. When it is put on spin, it drains then the drum rotates slowly in alternate directions, then just as it ramps up to spin the machine shuts off after powering up the drier motor briefly then advancing the timer to stop.
Ive checked main motor windings, brushes and tacho, also tried running machine with drier element disconnected.
This machine uses the hybrid type timer.
Any ideas thanks.
